I have a 2007 Donzi Classic with the 496 HO & Bravo 1 outdrive. The water pressure gauge has stopped working but the water temp. is normal. With muffs on I have good water flow. The out drive has side & bottom water pick-ups. Is there a pick-up for the water pressure that may be clogged? Have had this problem with the speedo pick-up. If so what is the best way to clear it?
Thanks for any help, Joel
P.S. first time user
