I just picked up this boat yesterday. I have a bunch of questions. Where can I find out what size & HP is the engine?
Mercruiser GM V-6
Serial # T12172KR
Also, what generation is the outdrive?
Outdrive: Alpha One
Serial # OL981578
Did the engine come stock with a Edelbrock 4 barrel carb? Serial # 1406 7129
Did the boat come with the 4 blade SOLAS prop on it? # (M) E4x14.25x19R
I got it to fire up with a new tank of gas, new filters, and an auxilary 12v fuel pump. My plan is to change the gear oil in the outdrive, engine oil & filter, spark plugs, top off the power steering fluid and the outdrive lift motor.
The fuel pump that wasn't working is a Carter P/N 152-875. I can not seem to find the same one to replace it. Can I use a standard 12v fuel pump in its place?
Do I need to replace the impeller? It is running at 165 degrees on the hose.
Anything else I should do or check before I take it out on a test run?
Thank you for your help.
Mercruiser GM V-6
Serial # T12172KR
Outdrive: Alpha One
Serial # OL981578
