Re: evinrude boat motor , first time boat owner, doesnt mind working on motor
Howdy, welcome to the forum
The impeller will be bad if the fins are hardened into a curved position ("taken a set"), or broken, or have dry-rot cracks. They should stick out straight and be nice and flexible when the impeller is off the drive shaft and laying on the workbench.
The housing or plate will be bad if it is badly grooved, rough where i should be smooth, or otherwise scored. Sometimes one can't even tell by looking at the housing that it is bad, I believe.
BTW, I don't fully understand your question. The impeller is the fan-shaped rubber thing that lies inside the water pump. The impeller is spun by the drive shaft and is one of the PARTS that compses the water pump.
What motor, BTW?
Good luck,
JBJ
