Re: merc 5.7L how long to run with no water
Bolo,as long as the drive is off there is no problem running the motor a a few minutes w/o water to get it fogged.<br />keep an eye on the temp while fogging,but get it done as soon as the motor is cranked up,dont wait for a minute before you hop to the fogging.I have done this a time or two before and have run the motor for as long as 5 minutes w/o any significant temp rise.There is an attachment available to get garden hose water into the bellhousing.It screws onto the mounting stud next to the water inlet .You can also just have some one hold a garden hose up against the inlet to force some water in.My guess is that you have already drained the block and dont want to do it again and if that is the case, go ahead and crank up the motor and fog it within a few minutes and get it done.Charlie
