Beachcraft 1
- Jun 25, 2011
- 17
I have 1977 Mercruiser 228 that have replaced with a 350. The power trim pump motor worked for a few seconds and then stopped. When I pushed the, I believe, the bottom button (In) a looked under the dash and saw a little smoke and spark. I took the pump motor off and it was grimy and corroded, but when I took it apart, specifically the commutater end plate, I noticed there was a wire, Service Manual 2 calls Jumper wire, that was not connected to anything. Should this wire be connected to something, the rivets on brush assembly plate, etc.? The manual seems to show it soldered to something, but I can't tell from the black and white 1970's pictures. I am debating whether to take the motor to have it rebuilt, is it worth it? Should I solder wire to correct location, clean and use if it works? Please advise.
Thanks
Thanks
