TheBlizzard
- Nov 20, 2010
- 48
Today while I was out on the water I noticed that when I was up on plane (3000 rpms - 4600 rpms) my oil pressure would be pegged at almost 80psi. At idle it would be around 40 psi. As soon as I would give it some throttle it would jump way up. Also I noticed while checking the oil that there was a small amount of oil in some water in the bilge area.
Is this normal? Is the oil level too high? Is the sending unit going out? I checked it and it seems normal with the boat in the water.
The boat in question is a 1989 Celebrity 20ft Cuddy with a Merc 5.0.
I searched the forums and found that some people said from 50-60 psi it normal under load.
Thanks in advance.
Thanks in advance.
