This is a 97 Chris Craft 17 Concept. 4.3L Vortec Volvo Penta SX Cobra outdrive. When purchased new by my parents, we were told the boat is all fiberglass/plastic, ie no wood in the boat, so nothing to rot.
The boat is taking some water in around the motor. When on the water, the bilge pump is on every 5 minutes pumping out water. Runs for a short time then shuts back off. Don't kill me, but the way I figured out it was buy filling up the bottom of the boat with water (hey, there's no wood in it, so what could it hurt?). I only filled it up enough to see where it was coming from, it didn't even get up to the floor level before I found it, probably still 6-8 inches from the floor. Just saw lots of water coming out around the drive.
I had a friend help me look today and as you lift on the outdrive, you can see the outdrive move away from the fiberglass, but we cannot visually see any fiberglass moving with the drive, just the drive itself. Then look at the inside as one person lifts on the out drive and we can see the inner plate that the outdrive is attached to move with the outdrive, again we don't see any fiberglass moving when we move the drive.
So do you think just part of the drive unit is loose and needs some bolts tightened up?
My background, well I'm a computer tech, but I've been working on my mustang that I drag race for 12-13 years and pretty much do my own automotive repairs. I've already replaced the seawater pump (external on the motor with a pulley), the main engine water pump, and given it some basic tune up stuff. My parents bought the boat new in 97.
Either way, here are the pics, give me your opinions...
