Hi Sea Medic
- Jul 8, 2011
- 1
Hi This will be my first post. This (2011) will be my first season with this 1985 sea ray sporting a OMC 5.0l I/O...last winter snow piled up on the tarp above the engine...little did I know that during the thaw that snow, now water was draining on the top of the engine. When preparing for boating I found the engine with near 0 oil and full...I mean full of water. It was in the cylinders as well...oil had filled the bowl of the carb..likely water pushed the oil up and out...well that explains the mess under the rear drain plug hole.
I have drained the oil...wd40'd my cylinders...compression test shows all cylinders @ around 155psi except one which is at 20psi....
I cleaned and reinstalled plugs, cleaned carb..etc to see if shed start/run...brand new oil/ filter...
Once the fuel bowl filled she ran well...had a bit of shake at first but after some throttle it ran smooth.
Prior to my first start I started it without water cooling just to see if it would go and it did....then I added water....
My dip stick shows milky oil/water mix which raised up the dip stick 4-5 in....lots of white exhaust smelling smoke...and oil oil/water exiting the exhaust in the stern drive.
also found small trace of oil/water milk in the exhaust manafold.....
sooooo....Im not sure if there was any water in the engine prior to thaw so im not sure if there is a chance of cracked block or heads ...
from what i gather I may be having a head prob or head gasket prob or do I known a chevy 305 anchor?
any takers.
any takers.
