I have 2003 Yamaha F115TR motor that cranks fine but will not fire. No spark at the plugs, checked one on each ignition coil.
I have isolated the issue down to something related to the main relay. I have removed the relay and bench tested it. Contacts close withe +12Vdc across Yel->Blk or Grn->Blk. Contacts have 0.52ohms across when closed. This could be a bit high, but not sure this is the issue. If I short the Red->Red/Yel wires in the relay connector the motor starts, so I know the issue is getting this relay pulled in properly.
I do not see +12Vdc at either the Yel or Grn terminals of the relay connector with the key in RUN or START. This seems to be the most likely issue. Unfortunately I do not have schematic for the boat (Lund 1700 Fisherman). From what I am guessing, the Yellow wire comes from the keyswitch which has +12Vdc at the keyswitch. The Grn wire looks like it comes from the ECU, but there is also a Grn wire that comes from under the dash.
I feel like I am really close, but struggling with next steps.
Anyone know where the yellow and green wires for the main relay come from? When should they be hot? What is too much resistance on the contact side of that relay?
On a side note, but may be related which is why I bring it up... my trim gauge has been acting up lately where it never shows the motor fully down. I ran the motor all week last week with no issues. Is there a chance this sensor has come out of adjustment even further and that the motor won't fire with the sensor out of adjustment? Would this prevent the main power relay from not activating?
