Re: Running an engine in a barrel or ears?
Depends what you want to accomplish...if you only want to flush the innards of the block or see if she will start you can use the muffs. If you want to see if it runs, or tune it use a tank. You can find a stock tank from a local farm supply that would do fine for all but the largest of motors. If you have a 20hp or less you can use a steel barrel or a plastic one of the 50-55 gallon variety. I am sure others will have some better ideas, but these have worked for me over the years...just some Thoughts
