I have a 1991 Johnson 9.9 and have two questions.
I put in a new water pump and now I am trying to re-assemble the lower unit and I can't attach the shift rod to the shift rod connector. When I put the screw in the connector first, the rod won't go through the connector opening and I can't find a way to fit the screw through the narrow opening of the extension unit to the shift rod connector after the shift rod is already inserted in the connector. Is there a special way this needs to be done?
I also cant remove the oil plugs from the lower unit-i tried PB Blaster and tapping on them but they still wont budge.
Any ideas from anyone on both questions would be greatly appreciated.
Thanks
George
Thanks
George
