Re: This trade worth it???
I would look at it this way, the 3 wheeler is antiquated, and the dolly replaceable. I would take the boat in trade. Even if it turns out to have issues, still has value. I realize the importance of rotten decks and stringers, but an uncovered boat is not more susceptible to more rot then a covered. How many times you see a boat covered and the cover is filled with water, slowly dripping in the same spot for months. Uncovered, it get wet and then dries, that boat should be self draining deck, worth the trade in m opinion. As for the trailer, (like buying a used car) expect tires, bearings, brakes if it has them to be replaced. That boat style here at the jersey shore worth 1500, running 2500
