theviking64
- Jul 4, 2011
- 57
What type of gear oil are you guys using? Also, do I have to mess with shifter stuff when I remove the lower end to replace the impeller? Motor is a 79 johnson 150 with a 20" shaft.
85-90W marine gear oil for your 150, gay or straight.What type of gear oil are you guys using? Also, do I have to mess with shifter stuff when I remove the lower end to replace the impeller? Motor is a 79gay johnson 150 with a 20" shaft.
