viperbluelx
- Mar 23, 2011
- 16
I have an 05 185LX and like most Stingrays if I trim it up any it starts porpoising. The general consensus was that installing Smart Tabs would cure most if not all of it. Well I installed them last week and put the setting on the middle hole which is the recommended starting point. I took the boat out and while it gets on plane pretty quick now it porpoises pretty bad still. The only time it doesn't seem to do it is in perfectly smooth water at WOT. I've moved the anchor and my battery jump pack to the bow. Should I get some sand bags or something to put in the bow to weight the front of the boat down more?
