2000 bayliner 1750 capri 135 hp mercruiser BELT BROKE **how do your replace it??
Bt Doctur
Re: 2000 bayliner 1750 capri 135 hp mercruiser BELT BROKE **how do your replace it?
Its it a mercruiser, remove the 2 bolts on the right side, remove spacer, R/R belt, install spacer
Don S
attachment.php
garysta
not enough room to remove replace belt, the bracket that holds engine height and in between the pulley is not enough room to install belt??? Help, rookies here
Ayuh,... So loosen, take off the pulley...
