larry22109
- Jul 7, 2011
- 2
Had all the carbs rebuilt last season because it was time, leaking and so forth. Got it back, runs great at low idle, get on plane but when i throttle up at about 3000 rpms it just bogs down and want to die. I did notice that the primer bulb was not full and hard so after pumping it up it runs like it should and then repeats the problem. Is this a fuel pump problem? Clogged pick up screen? Ethanol poisoning?
Was thinking about switching to external tank and test it again to try to isolate the problem.
