TBarCYa
- Apr 13, 2005
- 781
Yesterday, the breaker tripped on my blower motor at home and my housesitter reset the breaker and left the unit running. Today, there's very little air coming out of the vents which leads me to believe that the evaporator coils are frozen and restricting airflow. The plan so far is to run the heat for about 30 mins to thaw the coils then let it sit for 2 hours before turning the A/C back on.
First question... Does my diagnosis sound right? I've done some research online and the compressor running without the fan is a typical cause of the coils freezing which is a popular cause of low air flow.
Second question... Is my resolution going to cause more damage than I may already have? I've read that with a heat pump, that running the heat can speed up the thaw but I have forced hot air but assume that once the air handler gets hot, it will thaw the evap coils pretty quickly.
Any help is appreciated.
