Re: 150 black max overheating
I had a few pieces of gravel (oyster) on the inlet side of the poppet do that to me as well. It seems to have made the poppet open later than it should have. Ran fine at idle, and at WOT, after the pressure was enough to open it. As a matter of fact, gotta go do it again this morning. It ran PERFECT for a month, then drug a reef a couple times and it started again. One of my symptoms that it is the poppet is that its not coughing water out of the exhaust, only steam. Right now, mines not alarming again yet, but it's steaming again. The pisser gets its water from the thermostats, the other small amount of water the comes out the back (not thru the prop) comes from a different place. You can have one partially clogged and it still pee strong and overheat. I changed my water pump, housing, both tstats, and cleaned my poppet, all at the same time and wow what a difference!
