hondarider188
- Jun 15, 2011
- 160
Hello on my 1960 Johnson seahorse 18 what would be the proper trim adjustment to get the most performance out of the engine it has four different adjustments that you change by hand by simply lifting up the motor on the tilt the lifting up the bar and putting it into the desired notch. also is it better to have it set for different thing such as trolling or getting onto a good plane?
