Did my 1956 30hp fuel ump conversion see video/short shaft transome height
wbeaton
Re: Did my 1956 30hp fuel ump conversion see video/short shaft transome height
Your transom height is fine. The bulge where the water pump is located is only underwater at low speeds. When underway and on plane water is forced into the pump and the everything above the cavitation plate is out of the water. Lowering the motor will only increase drag, decrease performance and probably create a pair of rooster tails.
aaaahhhhhhhhhhhhhhhhhh.....................
