  #1
Old March 7th, 2004, 01:19 PM
phatmanmike phatmanmike is offline
Default besy way to remove paint from aluminum jon boat
my wife and i are gonna repaint our 14 jon, but the paint that is on there from prior owner is ugly, thick, and peeling.. and under that paint is a (looks like)profesionally done paint job. nice and shiney. we plan to remove ALL paint to bare aluminum and seal it with gluv-it, around all the grommets and such, and then primer it and paint it. we bought all the needed materials, paint, primer, sealer and marine tex( for a few small holes and such).. my question is this, WHAT THE HECK IS THE EASIEST/FASTEST WAY TO STRIP OLD PAINT? i have been using heavy duty stripper/ cleaner for cement, metal , and marine finishes from my local hardware store and using a 12000 rpm angle grinder with paint stripping wheel. just wanna know if i am already doing this the best way or if any of the super guru's out there have any secrets?thanks in advance
  #2
Old March 7th, 2004, 02:50 PM
snapperbait's Avatar
snapperbait snapperbait is offline
Default Re: besy way to remove paint from aluminum jon boat
I'd tend to stay away from the chemical strippers, issues with leftover stripper residue causing paint adhesion prob's later on.. Gotta make sure the surface is super clean before re-painting..I'd say your on the right track with the grinder/stripping wheel.. A wire wheel might do a little better on it, especially around the rivets, but if the wheel your using is working for ya, go with it...
__________________
Now understand, Commander...
That torpedo did not self destruct...
You heard it hit the hull...
And I...Was never here...
  #3
Old March 8th, 2004, 12:47 PM
jimpittman jimpittman is offline
phatmanmike,Yep the 4" angle grinder with a stiff wire wheel will do just fine. I just did my boat down to the bare shiny aluminum and repainted it with Duralux, aluminum boat green. I did prime the bottom first with zinc chromate but that was not necessary. Good luck.jimpittman
  #4
Old March 9th, 2004, 08:49 AM
Zoomer Zoomer is offline
Let me preface this by saying I'm new here, and by no means an expert. A few years ago I stripped a 14 ft. Crestliner to re-paint for duck hunting. It had at least 3 if not 4 coats of paint on it. There is a big difference between chemical paint strippers. I tried the hardware store stuff and it didn't work very well at all! I went to an automotive paint supply house and got something called aircraft stripper. It works 10X better than the hardware store stuff. One trick to using it is to slather it on, and cover the area with plastic wrap like Saran Wrap. Let it sit a while, and then scrap it off with a putty knife and use steel wool around the rivets. If you don't cover it, it seems to dry too fast and doesn't disolve the old paint as well. I was worried about the riveted seams, but no leaks here. I made sure I washed it off well before painting. If you do use aircraft stripper, make sure you follow the directions, it's really nasty stuff! It may only be available to paint professionals now, I'm not sure, but it really worked good for me. Like I said, I'm new here and there may be other reasons I'm not aware of for not using the chemical stripper, but it sure worked good for me. Good Luck!
  #5
Old November 2nd, 2009, 09:16 PM
Taperunner4 Taperunner4 is offline
Talking Re: besy way to remove paint from aluminum jon boat
Yes I have to agree with the different strippers giving different results. The Aircraft stripper is somthing we use in the motorcycle industry to strip wheel paint which is ridiculously thick. Some strippers are also harmful to aluminum so make sure to read the warnings on other types. On occasion i have also used Oven cleaner to pull off powder coats and other hard paint but there are warnings on the oven cleaner cans about aluminum so be careful if you choose to use it. Just wanted to throw in my 2 cents.
  #6
Old November 2nd, 2009, 09:37 PM
tmcalavy tmcalavy is offline
No. 1: media blasting
No. 2: plain old-fashioned spray on oven cleaner, read and follow all label directions.
A wire wheel on a grinder/drill will do the job, but you'll go through several wheels and you'll have little sharp bits of the wire everywhere...wear protection and do this in a safe place for easy cleanup.
  #7
Old November 2nd, 2009, 09:57 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Considering this post is over 5 years old....... I think the problem may have been solved...... let this drift slowly back into the archives and I will close it.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum boat paint help rick3b Boat Restoration and Building 6 July 19th, 2009 12:18 PM
paint my 14 aluminum boat help!!! caldog101 Boat Restoration and Building 0 April 24th, 2004 06:27 PM
what paint to use on aluminum boat? ironcitymadman Boat Topics and Questions (not engine topics) 10 August 28th, 2003 07:22 PM
best way to remove paint off of aluminum boat blueboat1 Boat Topics and Questions (not engine topics) 7 July 2nd, 2003 01:14 PM
Best way to remove old registration stickers on aluminum boat? nhboater Boat Topics and Questions (not engine topics) 5 August 17th, 2002 05:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
