Re: Johnson 130 V4 w/blown cylinder - advice
Oooohhhh. That really does not look too bad. I cannot see all the cyl wall, but if it looks like that all around, you do not have too much damage.
There are ways to fix this without a bunch of bucks, but they are RISKY.
Proper way would be remove powerhead, disassemble, machine, replace one piston and all four sets of rings, re-assemble.
If it were me, this is what I would do. (OK you guys, here it comes!!!)
This can only be done on loopers.
I would leave p'head on. I would strip down the front of the motor down to the crankcase front. Take off the port head.
Get a 3/8" drive 12 point socket on an extension and swivel and reach it in the front of the crankcase and remove the rod bolts on #4.
Remove #4 piston, Hone just #4's hole. Clean very very thoroughly. Look for gouges/ridges etc. If you have successfully honed out the cyl, re-assemble.
This way, you have fixed #4 for about 200 bucks max. VERY RISKY!!!! I have done it for a guy who has no money, and his motor is running great.
I also did it on my own motor when I FUBAR'ed and hit the starter with a piston stop tool installed in #1. It punched a hole in the top of the piston.
I fixed it just this way, and it runs.
The hardest part is the rod cap alignment. It took me about an hour fiddling with his to get it aligned right with the crankcase halves together.
You risk throwing a rod and killing the motor for good if the cap is not aligned.
You also risk not getting the cyl prepped right, and not having good compression when re-assembled.
But it can be done.
You only disturb #4, you only need one head gasket, one piston, one set of rings, four carb kits, and front end gaskets.
PM me with your phone number if you want to discuss all the ins and outs and risks in detail.
OH, and clean all four carbs to correct the lean condition that caused the problem in the first place.
