I have a 1992 60 hp evinrude. It hasnt been used in a while. I was cranking it over today checking a no start and notice only one coil is firing. Instead of swapping the coils I removed the power lead from the know good coil and connected it to the coil above it. I then removed the spark plug wire from that cylinder and I had spark while cranking. I put the lead back to its proper coil and had spark out of that coil. I guess it is save to assume it is not the coils that are bad. What should I check next??
