1989 spectrum 1706
MistahBiz
Hi all,
I'm looking at a 200 hp for my Spectrum 17ft , is this too much for my boat, what can happen if you go over the recommended limit for your boat?
Thanks
Mistahbiz
Re: 1989 spectrum 1706
Ayuh,... Do you mean Other than breaking the transom, 'n sinkin' the boat,..??
ezmobee
Your Spectrum is not a particularly well built boat in the first place. Wouldn't exactly be my first choice for overpowering. Please stick within the max rating of the hull.
paul1948
I have a 1990 24' Spectrum (I don't have a model number, but is is kind of like a pontoon boat except the hull is all more or less one piece split out like 2 pontoons). It is rated at 90 HP MAX. Hope this helps.
MistahBiz
Thanks all for the quick info, i cant find a rating but I think I'm just gonna stick with a max of 90hp..
ezmobee
Good plan. That light boat should perform great with a 90 (and probably much better than the Force is likely came with).
