98 Huricaine 201. 115 yamaha runs great, starts easy and then sometimes it will bog to the point you have to put it in neutral for 30 seconds before you can take off. It never stalls to where you have to restart. Sometimes after it has bogged down and you go to take off it runs rough (shutters) and won't go at all. Give it just a little gas and it will run ok and you can gradually get up to speed before it crumps out again. Sometimes when it is shuttering and running really bad if you give it just a little gas it will come out of it at the snap of your finger and run great again. Changed the water fuel separator, fuel lines, bulb a few months ago and it was fine. Just changed the fuel pump, bulb pumps up fine and stays solid. When this acts up pumping the bulb does not change anything. I will put volt meter on battery tomorrow cause it says 16-17. No rotten egg smell from the batt. (my guess is the gauge is off and unrelated) Boat was run all season every month since mid last year, just put 89 non ethonol in it and ran it several hours no change. Plugs looked good last year and clear filter on engine and filter on the bulb is flowing good. I am a fair car mechanic but boats are a different animal. I am thinking it may be electrical? Any thoughts any one? Thanks
