I have recently bought a 1983 Celebrity, 20' I/O 470 Mercruiser. The boat has not been started in about 2 years. Oil, coolant, and engine look fine and I can turn it over with wrench. Seems OK. I would like to know if there is something specific I should do prior to trying to crank the engine. I am going to unhook fuel line and use external tank to start it and clean filter. Anything else I should do?
The interior of the boat has been removed so this is definitely a project boat. So I expect you will be hearing from me again.
Thanks
Thanks
