Ignition switch/tilt trim fuse trouble
JrussLKA
Mercury 50hp, tiller, big foot, four stroke, EFI, 2001 - need help. I'm having a problem w a fuse blowing every time the key switch turns to the start position. The fuse is located in the main fuse block inside the cowling (holds 4 mini fuses) ... 15 A fuse in the "top right" position. A coincident issue is trouble w/ the tt function. The tt stops working when fuse is blown but works fine when the fuse is replaced and the key is off.
Any ideas .... Have done some troubleshooting w/ no results.
Thanks
JrussLKA
Re: Ignition switch/tilt trim fuse trouble
Any and all suggestions welcomed ... On vacation at the lake w/ a dead motor, not fun.
I thank you in advance for any advice,
Jruss
