kcfromohio
- Jun 4, 2011
- 56
I have a Matrix 12 fishing system from Humminbird. I have the base mounted on my dashboard. When I click the unit into the base, It goes in smooth and locks. When I try to remove the unit from the base,The release button is very hard to push and does not always disingage the unit from the base. As a result I have damaged the pivot point on the base. It seems as if the release button is not working properly. When not on the base I can only depress the button about 1/16 to 1/8 of an inch and it is very hard. It seems like trying to spray a can of wasp killer without removing that little plastic trigger guard.
I tried finding a Humminbird forum but I had no luck with that either.
Any Info and input would be helpful and appreciated!
