I found a hairline crack in the neck of the coil. One of the posts was arcing to it, not allowing it to start. I wrapped it in electrical tape and that stopped it. That isn't a permanent fix, especially when it gets hot. Can I repair it or does it have to be replaced? When I look online I find can find the coil for $70, but it also says that I need to chage the points too, $170. (note: use with #### part number and that is the points)
