Would appreciate some advice on two points.
1. Main Q: I need to take out the upper shift shaft to get exhaust bellows too in. The set screw came loose ok, but what's the next steps to get it removed? Any damage concerns or things to look out for?
2. I already put the exhaust bellows on the transom side and am ready to put the ujoint bellows onto the transom side since they are secured to the bell housing side. Did I make a mistake and now first need to remove the exhaust bellows in order to push the bell housing far enough in to get the ujoint bellows to lock in,,,,or can I manage it with the exhaust bellows either: put on both ends first, or just push hard enough with it sitting in the way.
I don't want to remove exhaust bellows now, it if I don't have to, but, will if needed.
Thanks
Thanks
