Replacing VRO Fuel Pump with Non-VRO
lahossman
I have a 2000 Johnson 70 HP (J70PLSSD) motor with a VRO. The VRO has always been disconnected and have only used oil/gas mix. Started having issues with the fuel pump and had it repaired once. A new VRO styled pump will cost between $300 to $450. It looks like I could replace the VRO styled pump with a Non-VRO for a lot less. Has anyone here done this? If so, what pump (part number) do I need? And, how do you mount it? Do need a different mounting bracket? I have read that the results are wonderful, after the replacement.
kenmyfam
Re: Replacing VRO Fuel Pump with Non-VRO
Results are pretty good.
Here is a thread on my conversion. may help you a little.
http://forums.iboats.com/showthread.php?t=265363&highlight=mixer
