problem with my outdrives
otto08
i hit a rock last night and now my propeller is not spinning. i really dont know much about boat, this is my first one. the prop have a lot of damage. i took it out last night but its seen to be good in the inside. the prop spin by hand when is in N, F and R. can you guys help me out with this one?
Bt Doctur
Re: problem with my outdrives
Need to know what kind of drive.
for mercruiser: first verify the shift shaft is actually moving to shift the gears in the lower unit.if the shoes are connected and it is in a straight line (fwd) and the prop still spins, then suspect a broken shaft internally.
