1988 Evinrude 15hp Rope Start Model BA15BACCS S/N R1787299
Work Carried out so far:-
Carb stripped cleaned and rebuilt,
New Plugs
New Engine oil
New Fuel Lines and primer Bulb
Engine Decarbed with Sea Foam
Very good compression in both cylinders
Engine is hard to start when cold but once warmed up starts on first pull.
Engine runs fine on the water for around 5-10 minutes then splutters and cuts out, then it won?t start until engine has cooled down.
The Engine is pumping water very well with a good jet.
Whats wrong with it?
New Plugs
New Engine oil
