windsoreight
- Sep 17, 2006
- 25
I recently purchased a 96 Playcraft 20' deck boat with a Force 75. It is rated for a 200. After spinning the prop trying to push the boat, I bought a 1987 Johnson 140 off a buddy. The motor runs fantastic. It has a 13 3/8 x 17 prop. I can only get 5100 rpms at 30 MPH and it uses a ton of fuel. I can trim the motor up and get 32MPH and almost 5200RPMs but that is it. I am not too concerned about speed but I do like it. I am more worried about RPMs, isn't there are certian cruise RPM. I have a 23 gallon tank in the boat and after a 2 hour trip I am running on fumes. The throttle cable has some slop and I don't know if that is the issue. I have not checked timing or compression. It has low hours and was owned by a marine machanic friend of mine since new. Starts right up everytime, pulls good, and runs smooth. The plugs look like it may be running rich also. Any advice would be appreciated.
