Re: Alpha bell housing help please
yes, I did use the new style bushings. the picture helps, I see the top of the bushing protruding into the exhaust area, so the bottom must be flush.
I did install it this way, but the shift shaft seemed to be way too tight, and wasn't exactly vertical. The bushing was really hard to seat, much harder than the old ones came out. either it was drilled wrong, or the bushing deformed with the installation procedure.
I am going to get another one and try again.
thanks for your help
