Last week (thanks to this forum), I found and replaced my slave solenoid on my 2003, 225HP EFI Mercruiser. I did this after working with the forum to troubleshoot and identified that my starting problem was solved when I jumpered the two leads on top of the solenoid (this being the solenoid on top of the block, not on the starter itself). I replaced that solenoid with a new one and voila, I'm back in business and the family is no longer worried about going out in dads boat and having to swim back to shore.
Got in this weekend feeling confident and started first time and from then on each time I needed to start it I had to short the solenoid again.
The only other thing that I can add to the story and I don't see any relationship is that the oil pressure and temp gauge don't register anything (but I don't recall if they did before either - new boat for me).
Any idea what would cause a slave solenoid to burn out like this? I can't find a wiring circuit that shows how these are wired to the rest of the boat, but sure could use one to help troubleshoot.
All help appreciated.
Thanks,
Jon
Thanks,
Jon
