69triumph
- Jul 2, 2011
- 10
Engine idles great. Engine throttles up with water cups on but lacks power under load. Engine will try to throttle up but dies back down and throttle has to be brought back to idle to keep from dying out. I have replaced the plugs, water pump and rebuilt the carb. The engine has low compression (about 115 on top and 100 on bottom) but with even that, shouldnt the engine run under full throttle, even tho with less power? Any ideas?
