someone1357
- Jul 24, 2010
- 24
this motor has been tuned up, the carb has been completely rebuilt, and the ignition system has been tuned up as well. Most of the time it is running the engine only runs on one cylinder and when it runs on both it misfires very often. The points are set to .020 and the spark plugs are new champion J4C set at .030. I did a spark test, and I saw a big fat blue spark jump across both spark plugs at the right time, every time. At this point the only problems I could possibly think of that are causing this is either
1. The air/fuel mix is for some reason not being burnt in one cylinder
or 2. no or not enough air/fuel mix is being delivered to one cylinder, therefore it does not fire.
pretty much everything in this engine has been fixed up, I don't know why this would be happening. could it be low compression in one cylinder? Maybe I should try a decarb or something? or maybe something shorts out in the ignition system from the vibrations of the running engine, so when I do a spark test (engine is not running) is comes out as successful, but that success does not translate to two firing cylinders during operation?
I used to have it running great, they're amazing little outboards (when they work properly )
any help/suggestions would be greatly appreciated
