Hello,
I have a 1985 125hp force. It runs good but didn't pump any water. I figured the impeller is bad so I took it all apart and found the impeller housing was worn so I installed a new housing, impeller, wear plate & gasket. Cleaned all the parts before re-assembly. After everything was put back together, I ran the engine but still after a couple minutes it still didn't pump water so I had to shut it down. I am using a large plastic tub filled with water. The water level is about 2" above the water inlets. Is this high enough? If so, what else could possibly be an issue for this thing not to pump water?
