so you swopped the coils and you can get spark using either ....not sure how you mean changed over . did the spark move with the coils or still only one spark on the same cylinder ......so lets start again... could be the contacts for the bad cylinder ...use meter across the coil ..should go 12v 0v 12v 0v as you turn the flywheel .....if it does then contacts good and its either the condenser or the HT lead plug cap rusted away inside ..plug lead easiest to check.
