Merc '76 175hp shifter issue
zrhunt
Hi all!
I am needing some help. After 2 years of tireless work and countless $$$ rebuilding the engine on my '76 Mercury Outboard 175 hp, I finally got in on the lake and got it to go somewhere. Ran and sounded like a beaut, with on exception. The shifting handle itself, not sure what its called, had a tooth break off a gear inside the little box right next to my steering wheel, and couldn't go anywhere... I just need a new shifter/throttle (the whole box, not the part inside the engine but the part up front, the control box) but can't find one anywhere online! So basically my question is, is it possible to buy them or do I need to try and find a similar boat and salvage it?I feel like I haven't been very clear and probably sound like a babbling bafoon, so ask me if you need clarification. See my picture of the needed peice for some clarification...
Thanks in advance for your help!!
Faztbullet
Re: Merc '76 175hp shifter issue
You need the older box due to the trim system setup ( reverse lock solenoid) and engine harness connection(large barrel 12 pin). You could use a newer box but would you need to change internal engine harness and rewire of trim limit/sender and reverse lock lock.(PIA)
