ole farmer
- May 2, 2011
- 10
I am resealing the lower unit and the two seal's right below the water pump I am in need of advice on. My kit came with two seals of the same outer size but one has a thicker rubber than the other. I didn't see a differance on disasembly but I realy didn;t look. should the heavier seal be installed to keep oil in or water out because of the water pump above???? Thank You
