My engine is cutting out when you go to full throttle, The last few times when I get it back to the dock then the motor will not shut off with the key nor the kill switch. I have had it in for repairs, they thought low voltage ( battery the first time) Replaced the battery, Tested same problem, they put all new wire harness on the motor,(Same Problem)'' Unsure they have now ordered the brains of the motor.
