KungFuCharlie
- Jul 1, 2011
- 3
I just bought a 1994 Sea Ray Sea Rayder jet boat with a 1994 Mercury 90HP Sport Jet (force) motor. The previous owner let it sit for a year with gas in it so the first thing I did was pumped out the bad gas and rebuilt all three carbs. I noticed that the cranking was a bit weak even with a brand new and fully charged battery. I also noticed that the bendix on the starter would disengage often as I was cranking and the motor not running yet. So I took the starter out, took it apart, cleaned it up (everything looked good inside), and installed a new drive kit (spacer, spring, washer, and bolt) and a new bendix (the old one was slipping internally).
Once I got everything back together the motor will crank without the bendix disengaging most of the time but there are still times when the bendix will disengage and the starter will rev up. I turn the key to the off position, wait a few seconds, and try again. Sometimes the bendix will engage and then disengage almost immediately and other times it will crank without the bendix problem.
I can get the motor to start and run both with a hose attached and sitting in the water tied to the dock. Was about to take her out for a test but then the overheat alarm came on. I am investigating that now and will post questions later if I cannot solve that one.
Anyway, any ideas why the bendix will intermittently disengage from the fly wheel or is this a common thing and I am just ignorant of it since this is my first boat?
Appreciate the help.
