This motor will suddenly (and always) quit a short time after reducing rpm to idle...it's almost like you turned the key off.
boat is in-water, not on the muffs...on the muffs this does NOT happen...!
no "sneazing" thru carbs or exhaust backfire
Things we've done include:
squeezing bulb as it drops rpm to idle...no change.
carbs cleaned (3x)....spray in all the holes seems to show all clear.
new plugs...@.035" and the spark energy SEEMS great
fuel delivery SEEMS ok in all respects
any thoughts or help as to what to look at would be greatly appreciated.
Thank you!
first post with a more info: June 29 10:56 AM
Thank you!
