whickety2011
- Jun 30, 2011
- 3
Looking for some assistance in repairing my cobra's lower unit. It's a 1989 behind a Chevy 4.3. Last fall I took the drive off, and stored it in the basement emptied of all fluid. I had a vibration problem last season, and trued up an engine alignment issue before reinstalling the drive. I also replaced the water pump impeller as its was a couple of years old. Anyway, after running down the lake with no problems, I lowered the drive in my driveway, only to notice a little puddle of 80 weight under the drive. Pulled the prop to investigate, and found it looked like it was coming from around the carrier bearing. I then pulled the drive and put air pressure (about 8lbs on the midlevel fill hole)
I have soapy suds bubbles, and audible air coming out of the lower unit just above the bolt in the 2 o' clock position holding in the bearing housing. Just to see if the bolts would even move, I screwed three of them out just fine, the one on the upper right (2'oclock) position felt loose at the initial turn of the ratchet. I tried to tighten it back up, to no avail. I think it's stripped. It won't even back out.
Could this loosness cause the seal to leak, or is the seal actually an o-ring around the carrier structure sealing it to the housing?
What to do??
Sorry about the long post. Oh...looks like no water in the oil, So I didn't do a vacuum test.
What to do??
