Re: small amount of gas/oil mix at intake of carbs of 94 force 120
Normal. Just to be on top of things.Do a compression test.That's a good indicator of future problems.Check the fuel pump diaphram.Ethanol is a problem with the rubber in older motors.
Replace any soft or extremly hard hoses.J
