Did the usual oil change this spring on my 4 stroke fuel injected 115 Johnson. 3 weeks into the season it started running rough and the oil light went off. I check the oil and it was about 1" over the full line on the dip stick. I changed the oil and filter agian, changed out the spark plugs, the old oil smelled badly of gas. Ran the motor about 2 hours and again gas in the engine oil. The motor runs fine at high and trolling speed, idles well. I don't want to run with gas in the oil.
Any idea what the problem could be?
