I have a 1998 Stingray with a 3.0l Mercruiser alpha 1 drive engine. Since I got the boat back there is a creaking/squeaking noise when you engage the engine. As you accelerate the pitch of the noise goes higher and then stops once you're over about 5 mph. What could I check? I want to ensure that all the fluids are fine and the dealer didn't screw anything up after bringing it out of winterization. The gimble bearing was replaced a year ago.
