1975 115 hp evenrude wont shift
dee colby
hi i boutght the boat 2 week ago i took it out on a lake last saturday for the first time. it shifted nice and smooth it went in reverse neutral and forward smooth every time. when i went to anchor i put it in reverse and it would/nt shift to neutral i can/t shift out of gear. any help will be much appreaciated thank you
Monte1961
Re: 1975 115 hp evenrude wont shift
Remove cable or linkage and see if it will shift by hand! post back results
Jim311
Was it recently serviced? When I dropped the lower on my little 9.9 I guess I positioned the clamp on the shift cable wrong or something. It shifted a couple of times properly, and then when I got it out on the water it wouldn't shift into reverse, but I could go forward or neutral. I had to drop the lower unit to reposition the clamp on the shifter rod and it started working fine. I'm wondering if yours worked loose or if perhaps you have problems with the shifter itself.
emoney
Could either be in the control or the linkage. Does it feel like it's engaging at the control arm?
dee colby
i don/t know if it was the guy i bought from said it was but it was ony his word. thanks
dee colby
i will remove the cable and try to shift on the main lever . thank you ror the reply
dee colby
i found the problem i took the cables off i can shift with my hand. the problem is with the power pilot. with the cables disconected from the motor the shift and throttle will not move. anyone know where i can find a new or used one as we don/t have a evenrude dealer in this area. thank all of you for the replys
